No power to head unit
xJustin
8
Usa
I'm upgrading the existing factory head unit in my 06 Nissan pathfinder. I found one of my old head units from a few years back (2005) when I upgraded my accord with a newer system. It is a pioneer deh-p4700mp.
I went to Walmart and bought a harness, wired everything up and plugged it into my vehicle's harness --- nothing, no power when acc or full ignition.
So I decided that there must have been something wrong with the head unit being the reason I replaced it in 05 so I removed the aftermarket harness and plugged in the factory head unit to the vehicle --- nothing. So I got worried I did something wrong, but when I sat the factory head unit on the mounts it started right up.
So I wondered if maybe it had to be grounded in the brackets to get power, I reconnected the pioneer and sat it in the bracket but still no power.
I'm extremely novice on car audio, I would greatttttly appreciate some insight from some of you more advanced guys.
And a quick question, the aftermarket harness has an "amp ground" wire and 2 "chassis ground" wires.
I have the amp ground capped off since I have no amp
And the 2 chassis grounds spliced together.
Is this correct?
Edit*
I ran the ground from the head unit to the (-) terminal on the battery, still nothing.
1. Nissans need a dedicated ground (those cars have a metal support beem that goes across the entire dash that you can ground the radio to).
2. Have you checked your fuses? Seems like a simple issue.
Here are the two radio fuses. The one in the car is typically for the accessory power while the one under the hood is typically for the radio's constant power.
10 AMP #4 PASSENGER SIDE DASH PANEL
20 AMP #29 PASSENGER SIDE UNDER HOOD
Physically inspect these fuses. Don't use a "fuse tester" as it can sometimes give false positives.
The wife started yelling "are you ever going to be finished" earlier so I reinstalled the factory head unit and cut the splices off of the harnesses.
But now I'm tempted to give it another try tomorrow.
For the sake of argument, if it were one of the fuses wouldn't the factory head unit have problems as well?
And would grounding issues cause the aftermarket head unit to not function or light up at all?
Now if I were to do it again, I would splice the two "chassis grounds" together, then connect both "amp ground" and the ground wire from head unit to the metal bar behind the head unit you
mentioned.
Is that correct?
Thank you guys for responding so quickly.
Some HUs are grounded through the antenna, some require their own wire. I always run another ground wire when installing any deck, regardless. Start with running a ground tomorrow
Any radio can technically ground through the antenna as the antenna is grounded to the chassis. The ground however is so far removed that it's not a good idea to ever use the antenna to ground the radio.
mentioned.
Is that correct?
If it was a fuse issue than yes the factory radio would not work.
I personally would never use those y-harnesses from Wal-Mart. Go to a shop and grab the 70-7550, if you have bose attach that black/white and the radio's ground to the bar behind the radio.
Up to you. It's weird what you are experiencing with multiple radios yet the factory works perfectly fine.
For clarification, I only have 2 head units.. Factory and the pioneer.
Where would the fuse be on the pioneer?
Also, I did not hook up the antenna when I was testing the aftermarket unit. I'm trying to be relatively cheap with this and was going to take it back in the event it would not work and get my $20 back.
Sadly I live a looong ways from any audio shops and Walmart is about my only option.
I'm about to go attempt this all again, completely reworking the harnesses and all.
Simple ,simple,quick test to check a radio for power..Take red/yellow(sometimes even orange if youd like)splice those together with about 1ft of wire/speaker wire,and take the radio to the car battery, and touch the pos post with the red/ect, and the black to the neg post..if she doesnt light up, more than likely it needs repair,Check to see if there is a 10amp fuse on the back of the radio also,may change that since its been sitting,may be the only issue
Ok I just threw in a 10 amp fuse, wired the red and yellow together, did the battery test and I got crackling + a lot of smoke from the head unit instantly. If it wasn't damaged before I imagine it is now. Probably not worth taking everything apart to reinstall at this point. I think I'm just gonna give up.
LOL..that hu was deff fried then from the beginning.I always test amps out and HU out from the batt, and never have had an issue, unless its bad as yours was..prob the reason why it was setting in the first place..
xJustin
xJustin
Usa
robert420
michigan born
    May 14, 2026
michigan born
    May 14, 2026
