No Power on my Powered Sub
Okay, I had to unplug my powered tube sub and then wire everything back in cus i had to empty my trunk. but anyways, I don't have any power now. I dont' know why. Maybe I am hooking it up wrong? could someone please help me?
It's a tube subwoofer and it's powered. I got the ground to chassis, RCa, and speaker wires hooked up. but now I have the yellow wire from the sub hooked up to the red and remote wire. is that right? or am i doing something wrong? do u think my sub is burned ? or am i just hookin it up wrong?
did you tape the end of the power wire when you took it out?
what yellow wire?
the red wire= power?
no your not supposed to remote to anything but the remote turn-on input.
pics?
No I didnt tape the end of the wire, I should have.
Red is the power. Yellow is the power wire from the sub amp.
There should be a remote wire coming from the amp then right? to connect those two together if you said there is two seperate connections. Cus if there should be one, then i think it fell out somewhere probably got pulled out somehow.
sorry no pics. i can try to get some pictures up later tonight.
and the fuse are still good.
Aziaddict
Aziaddict
Sacramento, CA
RandyJ
