hari-bhari
I had the unfortunate luck of buying a used MB Quart amp from CoilBurner on this forum, who turned out to be a well-known fraudulent seller who has since been banned. The amp arrived and I hooked it up by swapping out directly with my previous amp, which was working fine at driving my IDQ12.
However, once I hooked up the new amp, there was no more output. The amp powers on, the power light is green (not going into protect). My LPF is set to 80hz at my source (and turned all the way up to 250hz on the amp), Bass boost is 0, phase is 0, and gain is set to around 1/4. I am getting 2V input signal from my RCAs (checked with a DMM) while playing a 50hz test tone. However, on the speaker output terminals there is no output and both channels are reading 0V.
I've double checked my connections, remote wire, power and ground, etc etc and can't find anything wrong there. Any ideas?
