No output from amps HELP FAST PLZ
jbizzle
I just hooked up my 2 AQ 2200's and no sound is coming out..
I tested the amps before and they worked now they wont..
I even tried an amp separately and it wouldn't work..
PLEASE HELP I SPEND OVER 5 ****ING HOURS DOING ANOTHER RUN, AND HOOKING EVERYTHING UP.
check pos to neg wires? not really all that great at this but if the amp is on its gotta be the h/u or connects assuming its not blown. plus you been running it like a day ago so idt it blown
I checked them before I left the shop, for some odd reason, they were about 2.4-2.6 each..
And subs are dual 2s..
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Wired them like that..
probably 2.4 or 2.6 because of the amp's internal resistance.
the only things to check are power for the amp, input signal and the destination(subs) those are the only circuits involved. if you have signal and power to the amp, then it will either be 1. the amp(s) fuses or settings 2. the wiring to the subs.
I got it.. One problem was both amps were set to input slave, and inside the box I wired it wrong..
I put the pos/neg from ONE coil together, instead of taking a pos/neg from each coil and putting it together.
I'll pull the ****ing subs out tomorrow, no way I'm doing this today.. Working on this piece of shit since 3 ..
thanks mlstrass
jbizzle
jbizzle
Chicago, IL
mlstrass
