yamahondarider
Hey guys, I've got a strange problem that i can't figure out. I've got a Sony Xplode 500W Amp, and I am running the positive straight to the battery (25A inline fuse), and ground straight to the battery, and the trigger wire is coming from the power antenna activator wire off my head unit. I am using an RCA cable from the back subwoofer output on the head unit to the input on the amp. If I have the amp wired up to to the car as described, it comes on just fine when I turn on the ignition and radio, and the green power light is on, but nothing. no sound? Now, If I use my home made power supply (computer power supply) wired up to power and trigger the amp, and then turn on the head unit (still powered by car battery), and have the RCA cables set up the same, it outputs to the subs just fine. What is going on there? Any advice? Thanks.
