no bass:(
Grouding Problem? RCAs?
Or wait you have no bass at all? Is the amp in protect or is it just fine?
RCAs hooked up correctly and in the correct place?
Who hooked it up?
Remote wire hooked up? Amp turn on?
Sounds like you have a slight grounding problem, you should reground your HU.
There's also a good chance you have a high pass filter on, filtering out all your bass. Then you might have turned the gain up to compensate, so the thump is huge, but no bass from music. Check all settings on the amp and come back.
kelly_u
kelly_u
north dakota
10W3dodge96
ThxOne
    May 13, 2026
