No bass out of my subs
  • 4
Akis
22
chicago
THE GROUND,POWER,TURN ON LEAD, AND RCA'S ARE GOOD.
I put this system in a Toyota Camry and the sub was barley moving
than i put the exact same system in another car and it started working like crazy
I tried putting it back in the Camry and again nothing the sub was barely moving but in the other car it went crazy
does the other car have a aftermarket radio? if so make sure the sub control is turned up. also check your gains...and are you moving the amp and sub or just the sub to another car when checking it?
the car that the subs were supposed to work in is a toyota camry the car that we tried the subs in was a bmw 650i. And we are moving the box amp and sub so we wired up the car the same way. And it worked in the 650 but not the camry
RCA RCA RCA i mean almost evrything else has been elimiated your amp is not getting the singnal check your deck check your rca check it all if it worked fine with the same amp sub combo with no issues it has to be the signal!!!
brownvanman yah i kinda figured it would be signal but. MY PROBLEM is that i swapped out headunits and i still have the same problem?
American Bass has been one of the easiest brands to get in the US at prices so low it doesn't make sense to be a dealer shipping them from their...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
465
Akis
Akis
chicago
Akis
audiobaun
    May 19, 2024
    May 19, 2024
