Nice Memphis 16-MCA300 2 channel amp...
OmegaBunny
Moderator
Used memphis 16-MCA300 2 Channel Amp
Specs:
Full MOSFET Design
Built-In Fully Variable High/Low Pass Crossovers
Use Selectable 12dB or 18dB Per Octave Crossover Slope
RCA Bypass Output
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
2-Channel MClass Series Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
RCA Outputs: 1 Pair
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
4-Way Protection Circuitry
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 250mV - 5V
Dimensions: 18.09" L x 7.6" W x 2.4" H
Number of Channels 2
RMS Power (4 ohms) 150 watts x 2 chan.
RMS Power (2 ohms) 240 watts x 2 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 480 watts x 1 chan.
Peak Power Output 960 watts approx.
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.03%
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
Signal-to-Noise Ratio 88 dB
Fan Cooled No
Fuse Rating 25A x 2
WoofersEtc.com - 16-MCA300 - Memphis 150 x 2 ClassAB Full Range Amplifier
8-8.5/10 cosmetic
10/10 Function
Includes both endcaps. One is loose the other is nice and tight. Both stay attached and are included.
$175 obo
Shipping and Insurance Included
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
OmegaBunny
