Zesty
RCA cables are from Knu's 4g package. I'm a rookie and was wondering what the tiny wire in the middle was for? Thanks.
Ummmm.... don't listen to this guy. lolActually its for u to ground it, that way it helps by somehow filterin or doing somethin to the signal and help from ground loop or any kind of distortion... btw you shouldnt run the power wire/remote on the same side as the RCAs.
no its for when you turn on your headunit it will turn on the amp. Has nothing to do with a remote that is extra. Sends a signal to the amp telling it when to turn on and off.Ok, by remote turn on, do you mean for a remote control? Because my amp didn't come with a remote control.
if it was meant as a remote, why would they include another remote wire??? and, why is it shorter on one end?? dont you think that if it was meant as remote they would of left some play for you to be able to connect without a problem on both ends.Ummmm.... don't listen to this guy. lol
It's meant to be a remote turn-on lead... with SOME units, grounding the RCAs is a possibility, but that's not what this wire is intended for.
And running a remote turn-on lead near your RCAs isn't going to cause you problems.
