newb question on deadening?
95Prober
well, i bought lots of deadening and i will install soon when i get back home. this will be the first time i EVER used or expereinced the stuff. i know how do apply it thanks to these forums and i read up on its uses. but i just had a question. now, after applying it PROPERLY, which i will try and do, what will i notice the most INSIDE the car?? i mean outside, i assume most of the rattles etc. will go away hopefully, and inside will quiet the car from road noise. but how should i expect the bass?? compared to what it was? will it make the bass/vibration that much more stronger and impressive OR does it absorb the lower notes and affect the bass in a negative way?? thx
Basically what it does it that it stops as much rattles as possible and it limits the bass from going out of the vehicle, so inside of your car will be a disco, all you will need is a strobe light in the roof.
i recommend you get a DC to AC converter that plugs right into your cigarette lighter since u dont smoke and hook a power surge to the converter and go to RADIO SHACK and buy as many strobe lights as you can. plug all the strobes into the power surge and make sure the strobe lights are all set at different settings to make a more dramatic effect in lighting. Dancing will look way cool especially when u do the robot or do the wave thing with your arms. or if youre getting it on with a female (or male if youre a ****) it looks like your humping slow when youre actually humping fast and is quite intriguing
Their is no way your going to deaden your car enuff to notice such a drastic change.
well maybe you will..but for that you'd have to gut the entire interior and apply multiple coats of liquid and sheet deadener.
And a lot of rattles cant be solved with deadener. I put multiple layers on my trunk and my rearend still rattled as much as before.
Also don't get impatient while your doing it expect it to be boring, tedious and very time consuming.
95Prober
95Prober
Canada
AVSTANG02
