New XXX
no pics?... your killin me //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
no camera man plus i doubt id be allowed to take any pics, but its **** sexy
Seriously, wheres the vids?
I think he said hes going to post a vid on ROE.com as soon as he gets teh ok from david
Here are the dimensions specs:
12”
Mounting Depth - 12.75”
Mounting Hole Diameter - 11.375”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width -10.5”
Motor Depth - 5”
Basket Depth - 7.75”
Displacement - .24 cu. ft.
Weight - 72 lbs.
15”
Mounting Depth - 13.5”
Mounting Hole Diameter - 14.625”
Overall Diameter - 16”
Bolt Hole Circle - 15.25”
Motor Width - 10.5”
Motor Depth - 5”
Basket Depth - 8.5”
Displacement - .27 cu. ft.
Weight - 76 lbs.
18”
Mounting Depth - 14.75”
Mounting Hole Diameter - 17.375”
Overall Diameter - 19”
Bolt Hole Circle - 18.25”
Motor Width - 10.5”
Motor Depth - 5”
Basket Depth - 9.75”
Displacement - .30 cu. ft.
Weight - 78 lbs.
And as for T/S Specs, this is all they have out so far:
12”
Electrical Q Value -Qes:
Mechanical Q Value -Qms:
Total Speaker Q Value -Qts:
Free Air Resonance -Fs: Hz
Equivalent Compliance -Vas: liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency - SPL 1W/1m: dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.0 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
15”
Effective Piston Area -Sd: 810 cm^2
18”
Effective Piston Area -Sd: 1210 cm^2
Niggz89, tell your dealer to get that car metered that has it in it, and let us know what it hits, so we can get an idea the amout of SQL is capable here.
Anyone can say, dude this subs shakes my car. Even a little sub sold at walmart can do that. Im not dissing, but telling us that the whole car shakes, well thats just not good enough
We need more of a visual (well, you know wut I mean)
LMAO @ qtip...
nG
x2
hey is proud of his 138.x //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif , so basing his opinion off that everything must be real loud //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
x2
Damn striaght im proud of it, its the best in this area right now. So quit hatin. But seriously, back when I had my pyles, they shook the car, and they **** like a nigga getting his *** ***** by a broom in the barber shop.
I am exicted as hell hearing about your experience in hearing the new XXX, but thats not enough. Thats like a girl getting you horny, and then just walking away.
and you can't even get that far with them
well its superior sound they do some awesome work. its alot louder than my XXX setup was. i mena ALOT and i hit 142.x so make come to your own conclutions.
Savstyle
Savstyle
Fresno
Kevokrook77
Mike Mccabe
