Ok lets start off, I'm not super new to car audio. Ive ran 4x 10" SA-10s for the longest time in a compact car, off a AQ3500. I Ran 2 deka batteries in the tire well. It got quite loud, but recently I have sold that car and system and purchased a Hyundai Genesis Coupe.
I Am looking to build a loud, clean system for my new car. The only downside is i have about a 12-14inch height to work with in the middle. So I am opting for like 2x 10s.
The system I am looking at is the following.
2x SA Zv3 10" subs
2x Q1-2200D amps (1 per sub)
Running 2/0 welding cable or a good 1/0 audio wiring for big 3 and all power/grounding wires. (Need brand recommendations).
Possibly a battery since my stock Alt is only 130Amp and i cant find a HO Alt for my car.
Also I will be using a 4V Preout LOC spliced into my stock sub wiring in the rear deck, however I will disconnect and remove the stock 8" sub to allow airflow to the main cabin.
Im looking at a dual 10 box that blends in with my car like this Zenclosure box. Custom Sub Enclosure | Affordable Sub Box
But I will probably use 1" MDF with double Baffles. I am probably going to go seperate chambers for the subs and tune both to like 33 or 36 HZ with 45s in all corners.
Please post what you think of this setup, and what i should change, or any good brand recommendations or recomendations on who can help on building a box.
Thanks.
2x SA Zv3 10" subs
Thanks.
