Sold New Sundown SAE-1000D (first $300 takes it)
Audio Junkies
Price lowered to $250 shipped to the lower 48. Someone buy it before I decide to keep it.
This is a brand new in-box Sundown SAE-1000D amplifier.
This amp was sent to me by Sundown Audio to take pictures for them, and it is the amp in the pictures below. It was removed from the box for pictures and then put right back in the box.
First $250 via paypal (shipping included) takes it.
http://www.sundownaudio.com/amps/SAE-1000D manual_0309.pdf
SAE-1000D Manual
Features:
Double Sided Through Hole Epoxy PCB
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~16V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
Specifications:
*RMS power, 1 ohm mono--------------------1000W x 1CH
*RMS power, 2 ohm mono------------------- 600W x 1CH
*RMS power, 4 ohm mono-------------------- 300W x 1CH
*Signal to Noise Ratio ---------------------- >90db
*Low pass frequency crossover ------------ 35hz ~ 300hz
*Subsonic filter ------------------------------10hz~60hz
*Bass boost @ 45Hz ------------------------ 0~18db
*Phase shift control------------------------- 0-180degree
*Frequency response----------------------- 10hz ~350hz (+/- 1db)
*.H.D @ 4 ohm-----------------------------
*Efficiency @ 4 ohm------------------------- 86%
*Fuse rating--------------------------------- 25A x 3
*Input Sensitivity ---------------------------200mV - 6V (+/- 5%)
*Dimensions-------------------------------- 10.24"(W) x 2.0"(H) x 11.6"(L)
*MSRP-------------------------------------- $399
Hey Lukas //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sweet price for a nice amp, great job Jacob //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Audio Junkies
Audio Junkies
Tampa
NoLimit
