New Powerbass xta-4000d power tests.
uptwome2007
I just got a new powerbass xta-4000d, and I was able to do some 12volt power tests with it. Here are the results................
73 volts
38 amps
2774 watts
1.92 ohms
dc voltage drop 12.5
***The sub was wired to .5 ohm.
***All measurements were taken after holding burp for 5 seconds.
***Testing was done using a 51hz test tone (The burp frequency of my car)
Powerbass rates the amp at 4000 watts at 1ohm at 14.4 volts. I'd say it will easily do that if not more. I'm gonna do some more testing using a box wired at .25 ohm and I'll post the results. Can't wait!//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I did some one ohm power tests.....
54 volts
60 amps
3240 watts
.90 ohms
11.8 dc voltag drop
***The subs were wired to .25 ohm
***Test frequency was 51 hz.
I need to get my voltage up and try some more testing. I think I can get close to the 1ohm power rating at 12.5 volts rather the 14.4!
^^^Well we will see tomorrow when I add two nsb g3100's that should get my voltage up a bit. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I personally think that it will do it's rated power around high 12's low 13's volts. I'll post my results tomorrow when I'm done testing.
Those are the exact same numbers I got off an old xa4000... 2700 watts @ 2ohm (wired @ .66 ohm). I've always liked Powerbass amps. I'll be installing another one before the week is through but it's going to be wired @ 1ohm on a set of 9510s in a CRX. I'll clamp that and get back to you ASAP.
uptwome2007
uptwome2007
new jersey
uptwome2007
michigan born
    May 14, 2026
michigan born
    May 14, 2026
