New Jersey JL Audio 13W6v2 Subwoofer Sealed Box w Monster 402 Cable
defaultseller
$575 obo 13W6v2-D4: 13.5-inch Subwoofer Driver, Dual 4 Ω in a Sealed Box built to JL Audio Specs
Filled with Acousta-Stuf Polyfill Speaker Cabinet Sound Damping Material. Also comes with a Brand New JL speaker grill (Not Pictured)
Connected with massive Monster Cable MPC S402 XLN Speaker Cable
Sounds awesome, hits hard and is very clean. Was running it under powered with a JL Audio XD600/1. Was never powered by anything higher so its not beat up. I was in a car accident and my car was totaled so I am parting my audio equipment out.
13W6v2-D4 - Car Audio - Subwoofer Drivers - W6v2 - JL Audio
Monster MPC-S402-XLN-XT-2C (mon-121039-00) 24.6 ft. (7.5 meters)
13W6v2-D4
W6v2 13.5-inch Subwoofer Driver (750 W, dual 4 Ω voice coils)
This just might be the best-kept secret in high-performance sub-bass. If you aren't deploying enough power to make a W7AE the best choice, the 13W6v2 can deliver astonishing performance levels in less space, with less power and a lot less weight than a W7AE. Several technologies shared with the flagship W7AE's provide advantages in motor linearity and suspension behavior, which lead directly to reduced distortion and outstanding dynamic balance.
The 13W6v2 is best used with amplifier power in the 250W - 750W range and is optimized to operate in a 1.625 cu. ft. (46 l) sealed enclosure, or a 1.875 cu. ft. (53.1 l) ported enclosure. Detailed enclosure recommendations can be found in the "Specifications" tab.
Greater excursion capability and higher power handling distinguish it from our 13W3v3 subwoofer 13.5-inch subwoofer driver, allowing for higher output. Dual 4 Ω voice coils permit deploying the W6v2 as a 2 Ω or 8 Ω driver.
Box details.
Wall Thickness 0.75 in / 19 mm
Front Baffle Thickness 0.75 in / 19 mm
Volume (net int.) 1.625 cu ft / 46 L
External Width (W) 18 in / 457 mm
External Height (H) 16 in / 406 mm
External Depth (D) 14.125 in / 359 mm
F3 41.42 Hz
Fc 44.49 Hz
Qtc 0.7946
defaultseller
defaultseller
New Jersey
defaultseller
