NEW Rockford Fosgate 500s Amplifier for sale.
Channels 2 Per channel power
125 W X 2 @ 4 Ohms RMS
250 W X 2 @ 2 Ohms RMS
500 W X 1 @ 4 Ohms Bridged RMS
Total power 1000 Watts Peak/Max
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Bridgeable Yes
Crossover HP 50-210Hz 12dB per Octave
LP 50-210Hz 12dB per Octave
Tone controls Bass Control
0 to 18 dB @ 45 Hz
Signal input Low level -
Type - RCA(pr)
Voltage -250mV - 6 volts
Type - Plug(multi-pin)
Voltage -.5 - 11 volts
Line output
Phase control
Power input Connector - Block
Speaker output Block
Power supply topology MOSFET /
Output topology
Display Power -
Position - End mounted
Type - LED
Heatsink Type -Cast Protection Thermal Short
Type - Wired
Class - Marine use
Specifications S/N 100dB A-weighted
Damping Factor >200
Slew Rate 30 Volts/ms
IM Distortion
Stereo/Mix mono
Frequency response 20 to 20k Hz +/- .5 dB
Dimensions 2.40 X 9.80 X 13.35 (inches)
$200 OBO
foolishstyles@aol.com
Bridgeable Yes
0 to 18 dB @ 45 Hz
Type - RCA(pr)
Line output
Phase control
Output topology
Display Power -
Type - LED
Type - Wired
Class - Marine use
Damping Factor >200
IM Distortion
Stereo/Mix mono
$200 OBO
