new enclosure
dman4486
RememberedHowToChangethis
still waiting on the new amp...
here are some pics of my new enclosure
Nice job! Hows it sound?
My buddy used to run Hart amps and subs, but I wasn't sold on it.
i used to have hart subs, but i burned a coil on one and then the other popped the cone, and i trashed them....the amp is only 140w x2@2ohm so the mtx will be great.
the box itself is amazing...really low frequencies are super impressive especially for 10's at 140w rms. and the tuning is a smooth band, so no peaks
I need subs for my new car and this seems a reasonable way.
What subs did you use? Can you post dimensions/interior pics/drawings?
Hows it sound? Loud enough for you? Hows it sound around 60-150hrz?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-phoenix gold rsd10d's dual 4ohm 350rms
-this box is tuned for flat response...just over 2cuft per woofer(separate) and 24hz.
39.5" wide
~13" tall
~22" deep
-pics shown are what i have
-i have the lpf set around 80 hz so it is clean/loud from 80 and down
was the only way to get the tuning i wanted....and not make the box huge
True, you don't have to tune that low though, you can just tune higher then stuff the box to flatten it out again...you will loose a little low end, but not much...
true, but the lows are partially what i wanted, and i actually lost a mirror to a 27hz note last night:laugh:
dman4486
dman4486
Fountain Inn, SC
dman4486
