Sold NEW CUSTOM ARC AUDIO PEQ EQ W/POLISHED FACE & RED LED's
kyle454ss
NEW CUSTOM BUILT WITH POLISHED ALUMINUM FACE AND RED LED's ARC AUDIO PEQ EQ 7 BAND EQUALIZER!//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif $150+shipping
1OF A KIND CUSTOM MADE FRONT & REAR INPUTS WITH A NON FADING SUBWOOFER OUT!
7 Bands: 50Hz, 125Hz, 315Hz, 750Hz, 2.2KHz, 6KHz, and 16KHz Seven band equalizer with 12dB boost/cut Volume control with up to 9 volts output Low noise BI-FET op-design yeilds minimum distortion On-board 30V bipolar switching power supply 20dB headroom eliminates signal overload Main/Aux input selector Universal half DIN chassis for ease of installation. Gold plated rca input and output connectors
Frequency center : 50Hz, 125Hz, 315Hz, 750Hz, 2.2KHz, 6KHz, and 16KHz Boost/cut : 12dB S/N ratio : 110dB Frequency response : 10Hz-90KHz +/- 1dB THD : 0.05% Max output voltage : 9V rms Input impedance : 10K ohm Output impedance : 1K ohm Stereo seperation : 82dB/1KHz Dimensions : 30mm x 179 mm x 128 mm
kyle454ss
kyle454ss
NOR CAL
CRXican
