i like the kicker fuse blocks. They are built like tanks, and were maxi friendly.its a pos... sorry but it is, the blocks that hold the fuse become detached from the base plastic quite easily. The volt meter is pretty robust for what it is.
Looks like mine, but mine is a Lanzar and has worked like a champ for almost 3 plus years now.its a pos... sorry but it is, the blocks that hold the fuse become detached from the base plastic quite easily. The volt meter is pretty robust for what it is.
Im also guessing you've had the same fuse in there for that long too. Fuse holders that you rarely touch or mess with are great and all, but it hardly represents "use" of one unless you replace the fuses regularly and actually USE the equipment actively.Looks like mine, but mine is a Lanzar and has worked like a champ for almost 3 plus years now.
