sciontistbb
Hi guy, I did an install on my friends Pontiac G8 GT. He has 2 Fosgate P3’s that were wired to a 1000W 2 channel Sony amp which finally fried on him. He just bought a brand new Belva BB5000D mono-block with a Belva 1/0g wiring kit with a 150a fuse(thick as 4 gauge). I got everything hooked up correctly and the amp automatically goes into protect mode when we tested it. The protect light has a slow flash to it. I checked my wiring and everything seams to be wired ok. I use my DMM and the battery is resting at 12.5 and 14.6 with car running. Being that this amp is new, we connect it to his ***** Am which has walmart 8 gauge wire and amp works perfectly fine. We then try a Kicker amp in the G8 and we get another protect light while working perfectly in the ***** Am. I pull all the wire I just installed and rewired it with no luck. Both amps go into protect in the G8 while working fine in the ***** Am.
This is what we have:
2008 Pontiac G8 GT
Factory HU
L.O.C.
Belva 1/0 gauge wire kit
Belva BB5000D
2 Fosgate 4ohm DVC P3’s wired in series/parallel (4ohms)
2008 Pontiac G8 GT
Factory HU
L.O.C.
Belva BB5000D
