NEW amp for Alpine
probably a good idea to get amps for ur speakers before ur sub. U need a good front stage before u move on to the substage. Just speaking from experience //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2 and as for an amp, if not buying used, if your subs are dual 4ohm you could pick up a cadence txa1000d for $199 shipped from cadence. sure others will come with more/better suggestions but that's the first amp to come to mind in that budget new.
ok cool is this one better though if not ill go with the other from the website
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=270170875601&ssPageName=STRK:MEWA:IT&ih=017
but will this run 2 10'' Alpine type R's SWR-1042D
I know nothing at all about car audio so thanks for the help
If your Type R's are Dual 2 ohm, then yes, the second one is better (though, gunna be a little more difficult to hook up for someone inexperienced, but not hard)... If they are dual 4 ohms, then the 1st one is better.
That being said... order straight from Cadence as you will get a 2 year warranty with them too. The first one is the SAME price, and the second is actually CHEAPER straight from them.
http://www.cadencestore.com/ProductCart/pc/viewCategories.asp?idCategory=125
25
ya I saw that it is cheaper which is cool especially with a warranty. I will probally end up getting the 2nd one for the subs im getting. Which one is better all around though the 1st or 2nd thanks
jbomb269
jbomb269
SoCal
Kold_Killa
