DidUHearThat?
Precious Bodily Fluids
The amp is being powered from the front battery, they are all on one circuit. This is what I was warning you about. You have more than one source of power. The wire from the amp to the rear battery is now connected to the main battery as well. The wire that connects the batteries also connects the rear amp to the main battery, this is the same reason your rear battery was powering your car even though your main battery didn't have a solid ground. Go one step at time and make sure each step works properly before moving on to the next step.I hooked everything up again now that the front batt is hooked up correctly. When the amplifier is connected to the rear batt is automatically shows power, but still gives no output (when everything is hooked up). as soon as the power wire was hooked up to the rear batt it caused the hu to turn on (w/o key turned on) even though the rear batt had not been grounded yet to anything other than the amp...wtf
Now that you got your front battery working, make sure your second battery is working. Then you can move on to the amp/HU issue. You must fix the power first, before you can move on to the stereo.
Remove the fuse from the line between the second battery and the amp. You do have one there right? Ignore the amp for now and figure out why you can't turn off the HU.
