Ok so Im just looking for some clean power for the front stage of my car(highs and mids) What im planning on running:
Tweeters and Crossovers- KENWOOD KFC-T207
13/16" UFLC soft dome tweeters (pair)
flush- and surface-mount hardware included
4,500 Hz passive external crossovers with protection circuits
power range: 2-65 watts RMS (peak power 280 watts)
frequency response: 3,500-35,000 Hz
sensitivity: 90 dB
Mids-PG RSD6.5s
Power Handling: 60W/120W (RMS/Peak)
Impedance: 4 Ohms
Frequency Response: 45Hz - 20kHz
Sensitivity: 88dB
Now i need a amp to power these things just right but not break my wallet...here are a few ive looked up thanks for you help guys:
PIONEER GM-6300F - $130
60 Watts x 4, at 4 ohms
150 Watts x 2, at 4 ohms BRIDGE
80 dBA Signal-to-Noise Ratio (Reference: 1 Watt Output)
Bridgeable 4/3/2 Channel Capability
4 Channel Crossovers (HPF/LPF)
KICKER ZX350.4- $130
60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
Rockford Fosgate T400-4-$165
4 channel Mosfet power amplifier
60x4 Rms watts @ 4 ohm
100x4 Rms @ 2 ohm
200W RMS x 2 @ 4 ohms
Frequency Response: 20-20,000 Hz
sensitivity: 90 dB
Mids-PG RSD6.5s
Impedance: 4 Ohms
Sensitivity: 88dB
100x4 Rms @ 2 ohm
