Never ending Alt whine
Take the headunit to the amp and power it direct from the amps terminals. Jump the ignition to the constant on the deck harness. Use a new set of rca cables. Ensure that the amp is not mounted to any metal and that it is not touching any metal, put some cardboard under it. Do not plug the antenna in either. Retest and post the results.
Do this.
nG
On my brother's car, he dealt with it for over a year.
Then one day, I took a set of RCA's... shitty audiobahn ones... and ran them with the HU in my hand and straight to the amp (in mid air).
Got rid of the whine.
nG
not gonna bother reading th last 4 pages...but if it hasnt b een mentioned go to walmart and pickup the little 15 dollar ground loop isolator / noise filter, its an inline RCA module.....worked wonders for me when i couldnt solve my noise/whine with my sub amps...only happened when i plugged my old mtx 1501d's RCAs in. plug in that module and it fixed it jimminyslpiff
Did you guys ever fix this? I have the same car. //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif:fro://content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif:fro:
dalucifer
Not Minion Approved
dalucifer
Los Angeles
dalucifer
