Neon Light mounted on Int. Roof.
Are you not wanting to put in screws because you don't want to put holes in your car, or are you affraid you might drill into something important? If your not affraid to make holes, make some small ones and use zip-ties. What kind of material is behind your visors? Is it plastic or cloth?
When i mounted mine on the roof i just got some thin but hard sheets of wood, and some really wide but short screws(no longer than the thickness of the wood) then pull down the part of your headliner where you want to mount them and place the wood to the roof where the mounting screws will go with some carpet tape(doublesided tape)
then replace your headliner and screw into the wood and ta da.
MinorSkills
MinorSkills
Phenix City, AL
jonboy385
BP1Fanatic
BP1Fanatic
