Needing adivce on power tools
thisistiny
Graphic Designer
Not sure if this is the right place to post this.
Planning on buy a new power tool this weekend.
I saw Home Depot has a sale going on. what do you guys feel about this?
Ryobi 3/4 in. 12-Volt Cordless Lithium-ion Drill Kit - HJP002K at The Home Depot
Most popular ones seem to be 12v and 18v. I planned on getting the 12v like the one on the link. I mean. $70 seems like a good deal.
Are there any significant differences between 12v and 18v?
I plan on using it for normal CA installs...running wiring...hooking up amps... Making enclosures...etc..Maybe use it around the house here and there.
12v should be plenty for that, right? Or can it even handle all the drilling n stuff to make a descent ported box?
You guys have any recommendations on some brand named drills that might be better??
I would go for an 18v.. You will get much more power.
Skillz are cheap, but effective. If you're buying it for a once and a while thing like box building for personal use I wouldn't not recommend it.
I work commercial construction and I see mostly dewalt and makita. 18v ftw. Lasts longer and more power. Remember you get what u pay for. Yeh sure u can get a crapsman setup wit saw n drill n flashlight for $100 but I'm not sayin its gonna get the 2nd or 3rd job done that u try to use it for. Dewalt FTMFW
The craftsman 18 volt is actually one of the best drills i have ever used and have never had a problem with them at all.
Go with something affordable. I have used high end tools, and they do perform great, but cheaper tool do the same job, though you may have to charge your drills battery more often. I have had very good luck with cheap tools, just don't buy cheap drill bits saw blades, sand paper etc.
thisistiny
Graphic Designer
thisistiny
Las Vegas, NV
PIITB Wut Wut
vegang
vegang
