Need some help
  • Thread starter PanUn
  • Replies 0
  • Views 336
PanUn
Hello I need some help determining that this amp is powerful enough to support this sub. Also I havent decided on a Head Unit can someone please recommend a brand? Also will I need any more equipment such as extra battery and what type of box would you recommend? Sealed or Ported? Amp Specs are first followed by Sub. It is a single sub configuration. Thanks for your time and attention.
AMP
Rockford Fosgate Power T1500-1bd Amplifier Features:
Power Series Compact Class bD Amplifier
RMS Power Output:
4 ohms: 500 watts x 1 channels
2 ohms: 1000 watts x 1 channels
1 ohm: 1500 watts x 1 channels
Includes 0 Gauge Amplifier Kit and 2 Channel RCA's
1-Ohm Mono Stable
CEA 2006 standard ratings for real-world power
High Efficiency Class bd Topology
Variable 35-250 Hz Low-Pass Crossover
24 dB/Octave Butterworth Crossover Alignment
Variable 0–18 dB Punch Boost @ 45 Hz
Infrasonic filter: -3dB @ 28Hz 12dB/Octave
Removable Connections Shroud
4 Gauge Power & Ground Connections
Preamp Outputs
Wired Remote Punch Bass EQ port (P-EQ sold separately)
Bass boost: 24 dB
Frequency Response: 20-250 Hz
Dimensions: 8-3/20"L x 14-9/10"W x 2-3/20"H
Sub
General Features:
12" Dual 2 ohm T2 Power Series Subwoofer
Power Handling:
Peak: 2400 watts
RMS: 1200 watts
Impedance: Dual 2 ohm
Hard anodized aluminum dustcap and cone
High excursion Thermo-Rubber Santoprene surround
Mirror image symmetrical tear and fatigue resistant poly cotton spider
Parabolic triangular cone geometry support system
Precision cast and vented aluminum alloy basket and rigid frame
Optimized motor magnetics with extended vented pole and bumped backplate
Die-cast motor case and heatsink
Removable and reversible screw concealing ring
Ultra-high temp anodized aluminum voice coil and former
Fatigue resistant and reduced strain "stitched on" flexible lead wire design
Multi-point high-temp/high-strength neck joint bonding technique
Spun-laced Nomex insulating reinforcement collar
(IDHS) Inductive Damping Heat Sink
Custom insulated/isolated compression input terminal assembly
Flat edge wound copper clad aluminum wire
Triple stacked ferrite magnet structure
Sensitivity: 83.5 dB
CEA-2031 Compliant
PanUn
PanUn
JC, TN
PanUn
