Need some help figuring internal vloume, and port area
twistedmind
Second image is where my 2 amps r going to sit ( 18 " x 12" x 3" ) per rack, numbers are kind of hard to see
My Box design, assume External Dimensions shown, 3/4" MDF for build.
How much airspace is in there?
Port dimensions?
Id like to use 2 ports fireing towards roof, opposite ends of the box.
Thank you ahead of time for any help. Im trying to figure if I can fit 2 DD 3512's in my truck.
I realize right now im going to have a issue with the top subs mounting depth, what I had in mind was to replace my stock bench seat with a pair of racing bucket seats and building the actual sub mounts forward another 6 inches ( between the seats, Ala Corvette style ) and useing fiberglass to get the correct mounting depth, this is just a basic do I have enough airspace available sketch.
Thank you so far my man, Now if you would be so kind as to do a touch more math for me.
Useing the following measurements
Port Area (sq in) 44
Port Length (inches) 16
per sub woofer, whats that going to leave my internal volume at, once again assuming 3/4 mdf for port build.
Also, could you give me a hole size to make? example 12 inches long x 3 inches wide x ?? deep = 44 sq in of port
thats off the DD sight, those are the only specs they list other than woofer displacment, and box volume
the sight recommends 2.5 cubes per driver
the subs displace .336 each
well... if the total interior volume is just about 4.4 cubes before any displacements, thats about 2.2 cubes per sub w/o port disp. and sub disp. so i dont think your gonna get your 2.5 cubes per sub
im going to do some extensive fiberglassing where the subs are, its going to extend out from the main box. im just trying to figure out how far out it has to go before I hit 5 cubes after ports.
so example, my racing seats are 23" wide at the widest point x 2 so 46" of seat that leaves me 17" between the seats to expand towards the dash to make up some airspace.
Give me a few, I'll have answer for ya.
Port Size as follows - I. D. Size - 2.8750" x 15.3750" x 15.25" = .54 cu.ft.
That is also accounting for 3/4" MDF and the reason it's 15.25" length and not 16" is the 3/4" thickness of the top MDF is not part of the displacement.
So, to recap:
Enclosure total volume is 5.08 cu.ft
The two amp rack sections displace .68 cu.ft.
That leaves you with 4.39 cu.ft. before any additional displacements.
Subtract for slot port & walls( 3/4 ) = .54 cu.ft.
Volume now is 3.84 cu.ft.
So, to recap:
did you just figure for one port, or 2 ports?
if 2 ports is the 2.875 x 15.375 x 15.25 for each port? Or did you combine them into one massive port?
a real quick rendering of what my fiberglassing will do minus the sharp edges
so just this little minor addition adds over 2 cubes to the enclosure.
twistedmind
twistedmind
Texas
Mr Cabinetry
