Need Some Help Fast.. Need to order now!
THe A6004T shouldn't need anything heavier than 8awg unless you're planning on mounting it 30 feet away from the power source //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
You need positive power and negative ground cables run to the amp, you need RCA interconnects to bring the signal from the source to the amp, you need a remote turn-on lead from the source to tell the amp to turn on and off, and you need speaker wire from the amp to the speakers it is powering.
shanerz21
shanerz21
IOWA
Prowler573
