need resistor value for MTX RoadThunder RT2200 Amp #R408 I think Hart 2 Read
  • 1
zinda
I can't really read the board in that spot so I got a pix of te spot, it's the set of resistors located by the Power on Diode. the one next to it is R415.View attachment 26541360View attachment 26541361Also could use a pix of what copper runs attach to which legs of the fuse holder. Someone did a real number on this one. I'm just going to externally fuse it so I just need to know where to put the jumper wire.
138
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
105
446
343
751
zinda
zinda
Phoenix, AZ
zinda
    May 12, 2024
Brendon Jenness
    May 11, 2024
