Need quick advice.
  • 4
Dtrom
MAF
4,113
I'm bout to be running roughly 4.5k for a daily set up. Getting a 300a Alt. I have 1 Stinger SPV70 battery in my cargo area and I literally have ZERO room for more batteries. Am I gonna be okay to just use the one battery in the back? I'm gonna end up upgrading my starting batt to an SPV70 as well.
It's the MTX te4001D, if it even matters. I might be able to squeeze a bigger battery back there. But there's no way ill fit 2. Would it be okay to maybe put my stinger under the hood and like a D3100 or so in the back?
I have 2 2500s and a 100.4 with 300 amp E.A. alt, odyssey group 34 up front, and D3100 in the back. 2500s are strapped at 1. On music, at cruising speed, I do not drop below 14 very often. Not sure if that helps for you or not.
Exactly what I was looking to hear^ thanks man!
This might sound dumb but I've been wanting to know.. This is my first system that's required a H.O alt. I played a few songs with this set up on my stock electrical (140a alt)... And it was pretty loud, once I get my electrical beefed up is it gonna be alot louder?
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
449
346
754
Dtrom
MAF
Dtrom
Dtrom
    May 16, 2024
    May 16, 2024
