i need help from a profesional sub box desinger.
im rying to design a sub for my clarion ssw1001 signiture series dvc sub that is runing at 2 ohms
these are some specs i found on the net but cant find enclosure measurments.
Enclosure Airspace = 1.0 ft3 net
Vent = 2.5” diam. x 12.79” long
Fb = 30Hz F3 = 25.11 Hz
Max Peak Music Power 2,000 W
Max Power 1,000 W
Nominal Impedance 2 or 8 Ohms
Fs (Hz) 33.5
Qms 4.27
Vas (Ft3 / Litre) 0.533 / 15.1
Mms (grams) 190.7
Xmax (mm) 24
Sd (Sq. M) 0.03
Qes S/P 0.753 / 0.753
Re S/P (Ohms) 6.4 / 1.6
Le S/P (mH) 1.517 / 6.067
Bl S/P 18.47 / 9.236
Qts 0.64
2.8 V SPL S/P (dB) 80.66 / 87.75
no S/P (%) 0.073
Vd (ft3 / Liter) 0.071 / 2.0
Mounting Depth (mm) 177
Outside Diameter (mm) 277
Cutout Diameter (mm) 230
(ether i dont see the measurements im looking for or im just a little screwed up in the head)
Max Power 1,000 W
Fs (Hz) 33.5
Qms 4.27
Mms (grams) 190.7
Xmax (mm) 24
Sd (Sq. M) 0.03
Qts 0.64
no S/P (%) 0.073
