Tekneek
Ok so here is my setup...
4 Gauge Wiring
200AMP ANL FUSE
2001 RF BD1500.1
1 15" RF POWER T2-Wired at 2 ohms
Oh So i had 0 gauge Wiring running to my kicker zx1000.1 push comes to shove let my brother drive my car an he blew my amp ...Never will he drive it again. Anyways So i got the bd for a sweet price so i decided to buy it come to find out it only took 4 gauge wiring .. Now lol I know this is bad but i didn't have any money to buy 4 gauge at the time So i just took 8 gauge i had left over from a old old old build an tapped it to the zero gauge an plugged it in it was working fine in till i found out that the tape was smoking from the Power wire smh so I got some 4 gauge from a buddy an wired my power wire up an kept the power wire from my battery to my fuse zero an the ground zero everything worked well for a few days an bam the **** ground started smoking so i just bought like 2 in a half feet an ran it it worked for maybe a day or so now I drop voltage my lights dim so bad it cuts out at high volumes the only way i can keep it playing is if i turn my amp off witch i have a toggle switch for an cut everything down cut my amp back on an turn up things slowly an then she will stay on for awhile but i feel like i'm not getting as much as power as i had cause i'm dropping so much voltage an my Power wire is getting hot an my ground wiring is getting hot smh.. IDK what the deal is but if you guys can't help me then im try an buy 4 gauge reducers an put them on my 0 gauge an try again an see if that helps.. I DO not get it at all...!!!! Please Help me!!! Thanks in advance if you guys need any more details i will gladly respond.. ASAP
4 Gauge Wiring
200AMP ANL FUSE
2001 RF BD1500.1
