Need Help!
Echo42987
So I went ahead and plugged everything in the right way and after hooking up the ground, power, and remote line the amp, it turned on great. Got the blue light and everything.
Then I turned it off and went ahead and plugged in the speaker wires...After plugging them in I went ahead and turned the car back on. The amp turned on fine once again. Then once I plugged in the RCA's in, while the amp was on, the fuses popped. Then when I tried to insert another fuse, it sparked. Am I suppose to disconnect the power and ground before plugging in another fuse? Also do you have any ideas what my problem could be? I took a DM to each speaker wire to see if it was grounding out but got nothing...?
Thats a hard one, i might start by checking your power wire from the batt to the fuse and to the amp, make sure theirs nothing touching groung. the same for your remote wire . let me know what happends
Did all of that...
The only thing I've found so far was my rear speaker wire on my woofer, the neg was disconnected, other then that nothing.
Echo42987
Echo42987
Antioch, IL
Echo42987
