need help
audiobahnuser18
Alright guy's i found some amps online i been looking at but are they any good will be support 2 audiobahn 12's 500 rms 500 watts a piece dual 4 ohm voice coil. let me know i need some help
1.) Nitro bmw 482-2channel amp 1,000 watts
Here's the specs of it
1000 Watts
Super High Fidelity Sound
2 Ch Bridgeable Amplifier
Wire Bass Remote W/LED
Built-in Full Crossover
Variable Low Pass Filter (LPF) 30Hz-250Hz
Variable High Pass Filter (HPF) 50Hz-1KHz
Variable Bass Boost (0-18dB)
Variable Gain Control
2-8 Ohm Load Capability
Mosfet Regulated Power Supply (PWM)
3-Way Protection With LED Indicator
Frequency Response 20Hz-30KHz
Less Than 0.03% THD
High/Low Impedance Input
45 Power & Speaker Connector
Gold Plated RCA, Power & Speaker Terminals
Dual Color Power/Protection Status LED
Blue Interior Illumination
got any suggestions let me know
First of all, that amplifier is most likely 1000w MAX, not RMS, so you will be underpowering you subwoofers, plus the amplifier is over rated so you will be giving your subs even less power.. Nitro is a cheap knock off brand and they make cheap products, right down there with Legacy and Pyle... Save up some money and buy yourself something that will last and give you good results, you can get a Dirtected 1500D for around $180 on http://www.ikesound.com , that will do the power you want and is a great price...
Thats right in my price range ThX man Have you ever heard a directed power anything i mean do they last and not blow? let me know thx
P.S. thx for the link
audiobahnuser18
audiobahnuser18
Mi
audiobahnuser18
