Need help with planned setup? Suggestions?
dbaudio
NY
After hearing my TC OEM10 paired with my Sundown 1500D, my buddy decided that he wanted to outfit his car with a complete system as well. I told him he wouldn't be able to get an OEM 10 with a 1500D with his budget of $800 (which he said could be extended to $1000), and he said it's fine.
He drives a '00 Accord V6 Sedan and is looking to get a complete system installed on a budget.
Do you guys have any suggestions? I was thinking of the following:
-Kenwood HU or a lower end Alpine
-PG RSD 65cs front components (will they fit?)
-PG RSD 65cs rear components (or possibly just some Pioneer REV 6x9's for rear fill)
-Alpine Type R 12" Dual 4ohm in a DIY sealed box
-Amplifiers are still unknown. I was thinking along the lines of getting him an amp that will give each sub 650wrms at 2ohms. Then, 80-100 for the front components. Can amps that put out this much fit the budget? I was thinking maybe some Cadence TXA amps or maybe some used Rockford Fosgate amps.
-Generic deadener
Any suggestions to make this build a bit cheaper, or rather, make it better but at the same time still keep the budget under $1k?
Any help is appreciated. Thanks in advance!
If he has a total of 1k to spend on everything, he's probably not gonna be as loud as you are with your 1500 watts.
HU: probably around $150 for a decent used, maybe new one
Speakers/Comps: 2 sets: atleast $200
Wiring/deadener/DIY box/: ~$150
Speakers/Comps amp: ~$150 if he wants one
only leaving you with around $350 for amp and sub...
any other suggestions?
I think I'll stick with the two Type R's with possibly the JBL amp.
I'm moving towards getting a set (perhaps two) of PG RSD 65cs comps, but their unrealibility is a big turn off. What are the chances of me getting a faulty set?
dbaudio
dbaudio
NY
Pickler
