Need help With my Subs
sparelink
I have received a pair of JVC CS-LD3300 Subs from my cousin and wanted to make sure the box that they are in is the right size. Can anyone find the suggested size box for a sealed box for this subs. I know it should be some where around 1 c.f. per sub, but i am looking for the exact numbers.
Thiele / Small Parameters CS-LD3300
COPYRIGHT ©2000 VICTOR COMPANY OF JAPAN, LIMITED.
Nominal.Impedance,(ohms) 4
SPL,(dB,1W/1M) 93 SPL : Sound pressure level
Displacement,(Liter) 1.32
Hole Cutout Diameter,(inch) 11
Hole Cutout Diameter,(mm) 278
Mounting Depth,(inch) 5-3/16
Mounting Depth,(mm) 131
Re,(ohms) 3.8 Re : DC voice coil resistance
BL,(T·M) 10.12 BL : Product of Flux density and Effective Voicecoil-wire length
Vas,(Liter) 101.61 Vas : Volume of air equal to the driver compliance
Vas,(CuFt) 3.59
Me,(gms) 126.04 Me : Effective mass
D,(cm) 25 D : Effective cone diameter
Fs,(Hz) 26 Fs : Driver free air resonance
Qms 3.76 Qms : Q of driver at Fs considering only non-electrical resistance
Qes 0.76 Qes : Q of driver at Fs considering only electrical resistance
Qts 0.64 Qts : Total Q of driver at Fs
Pe[max.],(watts) 170 Pe(max) : Maximum continuous input power
Xmax.,(mm) 3.5 Xmax : Maximun effective voicecoil travel without distortion
Freq.Responce,(Hz) 16-1500
Magnet Weight,(Oz) 41.1
Magnet Weight,(gms) 1163
Voice Coil(Aluminum)Dia.,(inch) 2
Voice Coil(Aluminum)Dia.,(mm) 50
Here are the parameters, punch them into winISD and find out yourself.
I went to winISD and am even more confused then before. from what they say, i need a 32sq ft box. or did i miss understand there abbreviation. VB= Box volume in liters right?
if this is correct i would need a 4X4X2 box. that is giant.
sparelink
sparelink
Oregon
sparelink
