Astyl 10+ year member
Car Audio Enthusiast
Alright so i have an Alpine CDA 9835 Headunit and i noticed that you can go on I-Personalize and change some settings around on it, i went to the website, did all my changes, downloaded the file which is a .mp3 format file and then burned it onto a Mp3 CD
Then i went to download it on my headunit, when i click Yes it says "Searching" and then it dissapears and dosent display anything, and AFAIK nothing changes because my new opening message dosent come up even though i have that option turned on
Am i doing these steps correctly? Is there a different format i should be burning the CD as?
Also i noticed in the EQ settings it has User Preset 1 through 6, however when you go through them it dosent actually show you the EQ Curve like it does with the factory ones, so i have no idea what is what, is there anyway to check these? There are definate differences because it sounds completely different then having it on Flat i just dont know exactly what the settings are, and if i did burn a new settings file i have no idea what User Preset it would actually go on, 1 2 3 4 5 or 6, i have no idea what it would be saved under
any help would be appreciated, thanks
