NEED Help with LOC in 07 Tahoe. All help is welcomed.
Depends on how sensitive your dmm is. Also, have you adjusted the gain on your loc? My limited experience with loc's is that they do not put out a strong signal. Is your factory sub still hooked up? Or are you just running the speaker wires into the loc? I can not find anything about that particular loc as far as specs go.
Its hooked to the "sub wires". They are apparently not full range but just for subs. Ill try maxing the gains and higher volume.
When you are testing the RCA; are you only testing one at a time with the postive lead touching the middle pin, and the negative touching the outside circle shield of the RCA?
Yes I know that. Thanks for the input though!
Well, i hooked the LOC to 12v power and groundStill no dice. Hope the LOC aint bad.
Try hooking the factory sub back up and see if it works, then try connecting the loc while the sub is still connected. if the sub plays but you still don't get output from the loc just get another cheap one, I think I spent like 10 bucks on mine.
And don't max out gains on the LOC, I did that for a while and whenever I turned off my radio my subs would play a constant loud bass note until I turned it back on. (I guess whatever interference was picked up in the speaker wires)
Well LOC didn't work. Got the PAC unto to work though. All is good
Pyrofan
Pyrofan
Ga
Pyrofan
