Need help with door speaker
I'd hold off till you actually get the components and see how they fit. But you can make a spacer by just placing the speaker upside down on a piece of wood and outlining it. Then just cut it out and cut the speaker hole out. I would wait because if you jump the gun, you may have too thick of a spacer and your door panel not fit back right. You can use mdf for the speaker spacer. If you barely need clearance you could go with like a 1/4" thick piece and it do the job.
Tek18
Tek18
KY
accuab
