need help with comps!
Yes, those Pioneer comps are bi-ampable.
I think you can get by just fine with the amp you have, I don't think you need a new one.
ok guys im learning alot here (since i had somebody do my install for me) but isnt it better to bridged my amp and give it a clean 200 watts each set than give it a measly 70 watts to give it more thump or midbass?also i want it to be crystal clear even at low to moderate levels.
Well, we're talking bi-amping vs bridging... so the apples to apples comparison is 140W per side vs 200W per side, right?
You might notice a slight bit of improvement, but it depends on the speakers, really, if they can handle more power, or if you're just going to be losing it to power compression, heat, etc., and if you might blow them.
Just going by the theory of power-to-volume, going from 140 to 200 is probably only about 1dB difference, barely audible. Again, that's just a theory... I think it'll be somewhat of a push either way.
ok but i only have 1 set of gain adjustment for channels 1 and 2 right same as 3 and 4?
also the frequency adjustment 0-120hz i beleive how do i do that?
and the settings hpf, lpf or full?
You just have to listen to what your speakers sound like and turn up the crossover till you get no bass distortion from the mids at your higher listening levels.
So, usually 80-125Hz is where most people seem to cross their mids over.
maloy013
maloy013
clifton, nj
maloy013
