06dmax00camss
http://mobile.jlaudio.com/products_amps_lineart.php?amp_id=221
300/4:
http://mobile.jlaudio.com/products_amps_lineart.php?amp_id=254
I need to know where all the settings need to be set at.
300/4:
Rear Filter Controls:
-Frequency Range (1x or 10x?)
-Filter Slope (12dB or 24dB?)
-Filter Frequency Hz. (50-500?)
-Filter Mode (Off, Low Pass, or High Pass?
Rear Input Section:
-Input Voltage (Low or High?)
-Input Sensitivity (Adjuster screw?)
Front Filter Controls:
Front Input Section:
-Input Mode (2ch or 4ch?)
1000/1:
Preamp Output Section:
-Output Mode (Full-Range, Amp Filter, or Out Filter?)
-Filter Frequency Hz (40-200?)
-Filter Mode (Low Pass or High Pass?)
Advanced Bass Control:
-Infrasonic Filter (Off or On?)
-Infrasonic Frequency Hz (15-60?)
-"Q" (0.5-4.3?)
-Bass EQ (Off or On?)
-Center Frequency (20-85?)
-Boost dB (0-15?)
Amp LP Filter:
-Mode/Slope (Off, 12dB, or 24dB?)
-Filter Frequency (40-200?)
Amplifier Input Section:
-Input Voltage (Low or High)
-Input Sensitivity (Adjuster Screw?)
Subwoofer Output:
-Output Polarity (Normal or Reversed?)
-Center
THANKS!
300/4:
300/4:
Rear Input Section:
1000/1:
-"Q" (0.5-4.3?)
-Boost dB (0-15?)
Amp LP Filter:
Subwoofer Output:
-Center
THANKS!
