Need Help running 2 amps together
ninja85
Hi All, Im not all sure this is possible but I thought I would ask here hoping I can get help to make this work..I got 2 12" MA Audio subs in a MA Audio ported box. I want to run 2- amps to power this. ! is a Directed D1200 and the other Amp is a Pioneer GM-X524..Can I run these amps together? If so How would I go about it? Thanks in advance..
It'd be next to impossible to match the power and response you are getting from the amps. Cancellation and other effects become more likely. You want your woofers to get the same amount of power from an identical source, if not the same source.
ninja85
ninja85
New Jersey
ninja85
