need help repairing amplifier/welding** PICS
just for you mtl
i wub j00 //content.invisioncic.com/y282845/emoticons/cuddle.gif.bd1b29c179c0482f8313dbd790b74c94.gif
loll, imma give it another try tomorrow and see how it turns out, hope I wont burn the whole board! ill post some updates! and what do you mean by power leads are obese? loll
To properly solder these terminals you need to to do it from the back side of board, which will require removing it. Also you will need ~100W iron for this. I highly doubt that even after successful soldering amp starts to work - there probably either power supply FET's or outputs shorted, which lead to excessive current and and damage to solder connections of power terminals.
100W? are you kidding me?
i wouldnt use anything higher than 35W on that kind of stuff
If you are going to use ordinary (without load-adaptive thermal stabilization) iron, then you probably would not be even able to melt a solder around terminals with 35W, tip will be loosing temperature too quickly due to thermal capacity of huge terminal, acting as a heatsink.
meh, i would disagree with you on it, 35W has been fine for anything like this for me
looks kinda like a mini version of my first welds with a 250 amp stick welder and NO grinder //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
fail ...
SQBubble
SQBubble
MTL
goodstuff
