Need help, keep blowing fuses...
MTXman
Well about a week ago, my amp just shut off, and it started smelling like smoke.
So I said.. well, that's no good. Pulled over, and pulled all of the 30 amp fuses out, what do you know, 3 out of the 4 are blown.
So today I replaced all 4 fuses with four new 30's, thinking this would solve the problem. I turn on my car, hear a huge pop, so I shut off the car. What do you know? The amp is smoking like hell near the fuses and where the power/ground/remote wire hooks into.
Help?!
Yeah, I thought that might be the solution to this problem.
Who's that guy on here that repairs them for 100 bucks, I searched but I couldn't find him.
Disconnect everything....
Replace the fuses...
Reconnect the +/-/Rem only...
See if it turns on...
If fine... Plug in RCAs.... If not, your amp is shot
If fine.... Hook up 1st Speaker.... If not, then something's ****ed with your RCAs
If fine.... Hook Up Second Speaker... If not, you have a short in that speaker
If fine... There was a short somewhere that you have resolved... If not, then you have a short in that speaker
Thanks J3M, to what extent do I need to disconnect everything? Just everything from the amp right?
What if the amps internals is what's blowing the fuses but it still turns on?
MTXman
MTXman
Orlando, FL
thegreatestpenn
