Need help fast! 2 Ohm and 4 Ohm subs
ferret063
I can get a pair of alpine type R's for real cheap right now. The problem is one is a 2 Ohm sub and the other is a 4 Ohm. Is there anyway i will be able to use both of these? They will be hooked up to a kicker kx1000. Any help would be greatly appreciated.
Thanks,
Adam
if your amp is a zx1000.1 you want the dual 4 ohm sub, if its a kx1200.1 you want the dual 2 ohm sub. One sub isnt better than the other it all depends on the amp your running and where it makes its most power
The KX series is 1-ohm stable so if you run the dual 2-ohm sub in parallel, you will be running at a 1 ohm load. If you run the Dual 4-ohm sub, you will be running at a 2-ohm load. This is why the Dual 2-ohm sub is "louder." If you plan on running two subs, you will need to get 2 dual 4-ohm subs to get a 1-ohm load. Hope this help.
ferret063
ferret063
huntsville, al
dadydolas
