need help choosing subs plz help
el_miguelio
(2) Pioneer TS-W3001D2
Features:
Woofer Cone Material: Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround: Wide-Roll, 3-Layer Fiber Woven Ar amid Radial with Honeycomb Cloth
Voice Coil: Dual 4-Layer, Long Voice Coil
Voice Coil Wire: Copper
Voice Coil Bobbin: Phenol Resin Coated Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction: Double Stacked (110oz)
Basket Design: Aluminum Die-Cast Rigid Chassis
Gasket: 1-Piece Rubber
Wire Terminals: Integrated Single-Sided Silver Compression Terminals
Specifications:
Watts MAX. Music Power: 3000 Watts
Watts Nominal Power Handling: 1000 Watts
Frequency Response: 20 Hz to 150 Hz
Sensitivity: 92 dB
Ohm Rating: 2 ohm
Recommended Enclosure: 0.50 ~ 1.0 Cubic Feet
(2) 15" Solo-Baric L7 Series Subwoofer
Max Power Handling: 2000 Watts
RMS Power Handling: 1000 Watts
High-temp Dual 2 Ohms voice coil (428 Fahrenheit)
Frequency response: 18-100 Hz
Sensitivity: 89.4 dB
Titanium deposit impregnated cone woofer with rolled outer edge
Santoprene rubber surround
Full coverage back bracing
Poly-cotton semi-progressive spider
Spiralead tinsel-lead technology
Highly-efficient UniPlate pole-piece/back plate
Heat-reducing T-cut top plate
Solid pole piece
Cast-aluminum basket
Spring loaded terminals
Solokon 1 piece cone
SoloKon for strength and accuracy
T cut top plate for high magnetic field strength
Aluminum coil former (same as SoloX)
Pole venting at cone brace
Stitched and glued tinsel leads enable high excursion
Ribbed Santoprene surround
One Piece Ultra Rigid Molded SoloKon with 360 Degrees Back Bracing
(1) JBL W12GTi-MkII 12" DVC
12" Dual 6 Ohm GTI Competition Level Subwoofer
Power Handling:
Peak: 4000 watts
RMS: 700 watts
Impedance: Dual 6 ohm
Kevlar paper cone woofer
Nitrile-butylene surround
Differential Drive® Design motor
Symmetrical field geometry ensure linear cone travel and low distortion
3" Voice coil
Frequency response: 18-1000 Hz
Sensitivity: 91 dB
(2) 15" Punch Stage 3 Series Subwoofer
Power Handling:
Peak: 1000 watts each
RMS: 500 watts each
Kevlar Reinforced Semi-Pressed Paper
Poly-ether-ester Surround
Custom 10-gauge nickel plated push terminals
Dual linear spider with embedded 16-gauge tinsel leads
Extended pole piece and bumped backplate
2.5" 4-Layer 4 ohm high-temp dual voice coil with spun-laced Nomex® reinforced collar
Protective PVC textured magnet cover
Vented spider cavity
102oz. Double stacked ferrite magnet
Frequency response: 22-250 Hz
Sensitivity: 86 dB
(2) Memphis 15-MC124 12"
RMS Power Handling: 200 watts
Peak Power Handling: 400 watts
Double roll polyprene surround: Better control over cone movement
Ribbed polypropylene graphite cone
Dual flat spiders with graduated rolls
Single 4-ohm voice coil
4-layer winding on 2" Kapton® former
Vented basket and vented spider spacer
Aluminum heatsink
Sensitivity: 88 dB
Magnet Size: 50 oz.
Mounting Depth: 5.5"
I GOT THE 2 MEMPHIS AND THE 2 PIONEER SHOULD I STAY WITH ONE OF THEM OR SHOULD I BUY ONE OF THE OTHER ONES PLZ PLZ HELP
I WANT TO BE HEARD FROM LIKE 2 BLOCKS AWAY
I ONLY GOT 450 TO SPEND OR IS THERE ANOTHER SUBS I SHOULD USE
el_miguelio
el_miguelio
Laredo,TX
nu2spl
