uhtjoogoorih
I'll be installing a system in a new Tacoma, and have the Eclipse SC6900 components for the front and 2 Elemental Design 7Kv.2's dual 2ohm for the bass in the rear. Looking for two small compact amps to fit under the front seats. Basically smaller the better, as there's not too much space under there. And it seems these don't really need TOO much power to push it. The Eclipse website has the RMS rating at 80W and max rating at 240W. And for the 7Kv.2's looking to put no more than 200W to each. And also for the Kv.2's would you guys rather run a dual channel amp, or a monoblock amp? Any input is appreciated and thanks in advance. If you guys have any other suggestions of which amps and power to use, let me know. And they'll have to be pretty compact to fit under the front seats. I'll try to get the measurements of the space available asap.
