Need help choosing a powerful good amp for competing
Which amp would u choose i need some serious power
  • Total voters
    20
Ricky616
i have 2 12in 06 l7's dual 4ohm in a 01 cavy i need something that can push some power yet efficient i compete in meca in as3 im going to choose from 2 1501d's or Kicker zx2500.1 ,Orion2500d, or another amp along those lines that can do some serious power @1ohm //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif my bad i put 1 mtx i meant 2 also im going to have 2runs of 0gauge from front to back and 1 redtop under the hood and i dunno whiuch other batt im going to put in the back for daily driving for competing i can only have my front batt post the amp u guys have in mind thanks
what super powerful amp is going to be fuse efficient
uhhh kicker zx2500.1 can run on 70amps a 40 and a 30 maxi fuse //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif les how u liking that kicker?
70amps?
12volts?
840watts?
14volts?
980watts?
16volts?
1120watts?
sure, maybe it can be run with 70amps worth of fuses, if you only want about 800watts from it, off 12volts... //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
70amps?12volts?
840watts?
14volts?
980watts?
16volts?
1120watts?
Not true. Ill run some power/fuse tests today, i run mine on 50 amps of fuse at shows and im sure its way more then 980 watts
Ricky616
Ricky616
Chicago,Il
supraman1379
