need good loud box for 2 mmats procast 15s
the back of the blazer will take a box 42" wide , 30" deep , 30" tall and i can always get bigger amp if i need to . the mmats are 600 watts rms and i think they are under rated. the memphis amp is rated at 500 watts at one ohm , but i think it is under rated also . and i am trying to get as loud as possible. i want people to HEAR it then FEEL it then SEE it .
wow...
Anyway are if those are the dimensions that you can use and still be able to see then you have 19 ft^3 of space that's without port and bracing and sub displacement. I don't know those subs but you won't use all that most likely and still be at max cubes for those subs they will be loud but I don't know how loud never dealt with those.
498
377
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
414
621
cmftrading
cmftrading
albany ga.
Wildbillpb
maylar
    Jun 2, 2024
    Jun 1, 2024
